i have got a 1.5Tb ears hdd faced similar problem.
here are some temporary solution to the slow bug due to drop to PIO state.(at least you could save your data at a faster rate…)
change your hdd configuration to ACHI mode so it will force it to use DMA mode for data transfer
increase your temperature of your hdd to optimum temp of around 30-40+(seems like the temp cannot be too low or it will drop to PIO mode)
change registry to force back to DMA mode
below is the tutorial for forced DMA i copied from one website( http://sniptools.com/vault/getting-back-to-dma-mode-in-windows-xp)
Open RegEdit
Find the following KEY: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ Class{4D36E96A-E325-11CE-BFC1-08002BE10318}\000x
The last four digits will be 0000, 0001, 0002, 0003, and so on.
Under each key, delete all occurences of the following values: MasterIdDataChecksum SlaveIdDataChecksum
Reboot the computer. Windows will now redetect DMA settings.
do check this article for more info about the issue IDE ATA and ATAPI Disks Use PIO Mode After Multiple Time-Out or CRC Errors Occur http://support.microsoft.com/kb/817472/
and lastly, of course i’m not 100% sure if this will work for all type of problem, but i hope this will help some to at least save their precious data…
