Reading of MOV file from Canon Camera (Audio does not work)
Some one can help me on issue related to the MOV file created with a Canon Camera (EOS 550D). The WD TV Live Hub cannot read the Audio file. It is a PCM an not AAC. Should I convert the .MOV file before to put it in the WD or there is some patch for WD ?
Thanks,
Dave
Please post the full TEXT output of MEDIAINFO for such a file.
http://mediainfo.sourceforge.net
Below the text output of MEDIAINFO for one of my .MOV file:
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 519 MiB
Duration                         : 1mn 35s
Overall bit rate                 : 45.7 Mbps
Encoded date                     : UTC 2011-08-30 18:57:14
Tagged date                      : UTC 2011-08-30 18:57:14
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Baseline@L5.0
Format settings, CABAC           : No
Format settings, ReFrames        : 1 frame
Format settings, GOP             : M=1, N=12
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1mn 35s
Bit rate                         : 44.2 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Original height                  : 1 088 pixels
Display aspect ratio             : 16:9
Original display aspect ratio    : 16:9
Frame rate mode                  : Constant
Frame rate                       : 25.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.853
Stream size                      : 502 MiB (97%)
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format                           : PCM
Format settings, Endianness      : Little
Format settings, Sign            : Signed
Codec ID                         : sowt
Duration                         : 1mn 35s
Bit rate mode                    : Constant
Bit rate                         : 1 536 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 17.4 MiB (3%)
Language                         : English
It’s the fact that it’s using Signed PCM audio, which isn’t supported.
http://community.wdc.com/t5/WD-Elements-Play/Strange-problem-with-MOV-format/m-p/171266/highlight/true#M772
Ok. Is there any sw patch to fix the problem? Will WD support this format in the near future?
No and maybe.
Folks,
it works with the latest version of FW (2.07.17) and re-bootin the system every time. I have to un-plug and then plug the power cable every time I want to use the WD.
