Re: Forum Cut and Paste Problem
hi, I want to ask about the copy paste method for My Book Essential 2TB.
I read that if I want to just copy and paste files I want, the WD SmartWare should be uninstalled.
Is is ok if I just let it installed? What is the effect?
Really hope that someone can help. Thank you
I moved your message only because Forum Feedback is for issues with the community.  But in answer to your question, you should be able to cut/copy and paste into you My Book Essential even with SmartWare running.  SmartWare uses a folder to back up into.  So, anything outside that folder is fine and won’t be affected by the backup, nor will it affect the backup.
Oh, sorry about the miss board… And also thank you, I get it now, very helpful
