After Updating to the Latest Firmware 3.03.13 if you decide to Rollback to an earlier Firmware (eg.2.07.17)
the Hubs Internal Scraper No Longer Works !
_ This is how to get it Functional Again on Earlier Firmware. _
This Following Guide Assumes you a running Firmware 2.07.17 with a Non-Functioning Scraper.
1. This link is for Firmware 2.03.24 this is NOT Rollback Firmware it’s an earlier Proper Firmware Version.
http://download.wdc.com/wdtv/wdlivehub_2.03.24.zip
2. Extract the 3 Files onto a Fat32 Formatted Flashdrive:
wdtvlivehub.bin
wdtvlivehub.fff
wdtvlivehub.ver
3. Open wdtvlivehub.ver with Notepad and change the Version Number eg.
From This:
VERSION=‘2.03.24’
LOCATION=‘wdtvlivehub.bin’
PKG_LOCATION=‘wdtvlivehub.pkg’
To This:
VERSION=‘2.08.18’
4. Insert the Flashdrive in the Hub’s Front Usb Port and Proceed to Upgrade Firmware as per Normal
5. After 10-15 Mins the Hub will now be Running Firmware 2.03.24
6. Download Rollback Firmware 2.07.17
http://download.wdc.com/wdtv/Rollback_wdtvlivehub_2.07.17.zip
7. Extract the 4 Files onto a Fat32 Formatted Flashdrive : (No need to edit the *.*ver file)
wdtvlivehub.bin
wdtvlivehub.fff
wdtvlivehub.ver
wdtvlivehub.bi2
8. Again, Insert the Flashdrive in the Hub’s Front Usb Port and Proceed to Upgrade Firmware as per Normal
9. After 10-15 Mins the Hub will now be Running Firmware 2.07.17
10. Enjoy using a Functioning Internal Hub Movie and Music Scraper again on Firmware 2.07.17
