Rca cable not long enough
Hi
The RCA cable that comes with the device is not long enough for me. Does anyone knows where I could get another one? I tried checking monoprice but I wasn’t able to find any.
Thank you
Have you tried Radio Shack? If you’re in the US …
I’m not in the US :slight_smile: but i should look at someplace similar. If any one has a good reseller on the web, it owuld be appreciated
thank you
psy66 wrote:
Hi
Thank you
Just get an extender.   Available anywhere.
Beware the WD AV lead does not have standard wiring so you may buy something longer and it may not work. Just get a longer cable with rca connectors on both ends and then connect to the WD cable with female to female rca adaptors or a 3 rca male to 3 rca female lead.
http://www.amazon.com/SF-Cable-Female-Audio-Extension/dp/B004PFD0AS
