so my WD my Passport stop working iam pretty sure that i didnt drop it on floor or something . the file system is showing its RAW . so i run chkdsk and the problem was solved its NTFS now i can see all data there but copying is extremly slow like 1 gb takes about week . and also when i unpluge (safetly) the problem starst over again (RAW file system no files and so on)…
also i realized that the USB cable need to be in one posittion to make hdd visible for pc ( he is blicking if its not in that possition but computer didnt see it ) .
My question how can i fix this problems? i cant lost that data pease help . thank you
