Hi guys
I cannot update to the previous firmware. I have done all the steps but when I type:
updateFirmwareFromFile.sh sq-030401-230-20140415.deb
I get an error message:
-bash: /usr/local/sbin/updateFirmwareFromFile.sh: /bin/bash^M: bad interpreter: No such file or directory
I think it’s an error on the updateFirmwareFromFile.sh file. I have edited it using WordPad.
Can anybody upload in any server the correct and EDITED updateFirmwareFromFile.sh file??
Thanks in advance
xslip
July 23, 2014, 2:26pm
22
BTW, you may just edit /etc/version file via nano and change version from 4 to 2. Then update will go flawlessly.
CLOUD:~# nano /etc/version
File is here, except it is taken from previous firmware, not latest v4.
https://drive.google.com/file/d/0B0MkQQVqqs20WWxBTVc1OU43ZEE/edit?usp=sharing
Hi xslip
Thanks for the file but I’m seeing that this is the ORIGINAL file, not the MODIFIED.
I need the MODIFIED one with the # before the lines, because if I modify it with WordPad, I get the error message
xslip
July 23, 2014, 2:52pm
24
I do not have modified. I suggest you to run
nano /etc/version
then change 4 to 2 in it. Then Contrl+X, then Y to save the result
After that this shell script should run correctly. For me it helped without any changes. Also you can modify shell script with the same nano command, insert ‘#’ where needed, than also Cntrl+X and Y to confirm.
Please do not forget to run
chmod 777 /usr/local/sbin/updateFirmwareFromFile.sh
This will give full access to file (including rights to run it) to every user of ssh
there’s an easier way to roll back your FW. if you don’t mind voiding your warranty. ill just finish reading the guidelines so i know if i’m gonna violate anything for sharing something.
I finally got WD support team to assist me to downgrade. It’s fairly simple and requires very minimal SSH. I have created a thread with the instructions. Link to the thread -
http://community.wd.com/t5/WD-My-Cloud/Easy-method-to-downgrade-to-previous-version-of-the-firmware/.
dl3l3b
August 5, 2014, 11:28am
27
Thanks work great
I have some great sofftware installed and 64k page size not compatible
I’ll banned the 4.00 from my nas
