I can’t seem to get my new WD TV Live to pull metadata from thetvdb.com or from xml files for TV series.
I have my TV shows on a WD MYBOOKLIVE in a share called TV, I added that share to “My Media Library”.
So in that share I have
Monk\Season1\Monk.S01.E01.mkv
\Monk.S01.E02.mkv… etc
\Season2\Monk.S02.E01.mkv
\Monk.S02.E02.mkv… and so on…
When I select “Get Content Info” I get “No Content Info Found”
So I downloaded Media Center Master, and the XML converter for Live HUB. I tried each one, they both generated xml files, with file names that seemed to match perfectly with the file names for my mkv files. Yet nothing. All I get is ulgy looking file names when I view the directories in TV Live.
I also tried another TV series so, it’s not just that series.
I’m totally stumped…anyone have any ideas???
Thanks!
