I am trying to set up a static IP for my My Cloud EX4 but it keeps on coming up with an error when I try to use the IP assigned by my router.
When I use the dashboard to modify the IP address (via the Settings/Network/Network Services/IPv4 Network Mode - change from DHCP to Static) I get the following error when I try assign the IP which has been automatically assigned by the router. i.e. the My Cloud IP is 192.168.0.6 but when I try to assign the same IP statically I get: The IP address input is the broadcast address for the set subnet mask and cannot be used. Enter a valid combination of the IP address and subnet mask.
The other settings are:
Subnet Mask 255.255.255.0
Gateway IP Address 192.168.0.1
DNS Server1 192.168.0.1
DNS Server2 127.0.0.1
any advice would be much appreciated.
Many thanks
Bob
