Problems re-installing transmission
One day transmission stops working
I go in through ssh and get a message about the RSA ket being changed… I fix that
Then try to re-install transmission and can’t get the guide here to work…   http://community.wd.com/t5/WD-My-Cloud/GUIDE-Transmission-2-82/m-p/619597#M1322
All help would be greatly appreciated
WDMyCloud:~# cp /etc/apt/sources.list /etc/apt/sources.list.bak
WDMyCloud:~# echo deb http://ftp.us.debian.org/debian/ sid main >> /etc/apt/sources.list
WDMyCloud:~# apt-get update
Ign http://ftp.us.debian.org wheezy InRelease
Get:1 http://ftp.us.debian.org sid InRelease [205 kB]
Get:2 http://ftp.us.debian.org wheezy Release.gpg [1672 B]
Get:3 http://ftp.us.debian.org sid/main Translation-en [4480 kB]
Get:4 http://ftp.us.debian.org wheezy Release [168 kB]
Get:5 http://ftp.us.debian.org sid/main armhf Packages [6413 kB]
Get:6 http://ftp.us.debian.org wheezy/main armhf Packages [5693 kB]
Get:7 http://ftp.us.debian.org wheezy/main Translation-en [3852 kB]
Fetched 20.8 MB in 1min 7s (309 kB/s)
Reading package lists… Done
WDMyCloud:~# apt-get install transmission-cli transmission-common transmission-daemon
Building dependency tree
Reading state information… Done
The following extra packages will be installed:
  ca-certificates init-system-helpers libcurl3-gnutls libgcrypt11 libminiupnpc8 libnatpmp1 libsystemd-daemon0 minissdpd
Suggested packages:
  rng-tools natpmp-utils transmission-gtk
The following NEW packages will be installed:
  ca-certificates init-system-helpers libcurl3-gnutls libminiupnpc8 libnatpmp1 libsystemd-daemon0 minissdpd transmission-cli
The following packages will be upgraded:
  libgcrypt11
1 upgraded, 10 newly installed, 0 to remove and 245 not upgraded.
Need to get 1469 kB of archives.
After this operation, 3906 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://ftp.us.debian.org/debian/ sid/main libgcrypt11 armhf 1.5.3-3 [241 kB]
Err http://ftp.us.debian.org/debian/ sid/main libcurl3-gnutls armhf 7.35.0-1
  404  Not Found [IP: 128.30.2.36 80]
Get:2 http://ftp.us.debian.org/debian/ sid/main libminiupnpc8 armhf 1.6-3 [21.3 kB]
Get:3 http://ftp.us.debian.org/debian/ sid/main libsystemd-daemon0 armhf 204-6 [18.7 kB]
Get:4 http://ftp.us.debian.org/debian/ wheezy/main libnatpmp1 armhf 20110808-3 [8194 B]
Get:5 http://ftp.us.debian.org/debian/ sid/main transmission-common all 2.82-1 [254 kB]
Get:6 http://ftp.us.debian.org/debian/ sid/main init-system-helpers all 1.14 [12.5 kB]
Get:7 http://ftp.us.debian.org/debian/ sid/main transmission-daemon armhf 2.82-1+b1 [176 kB]
Get:8 http://ftp.us.debian.org/debian/ sid/main ca-certificates all 20130906 [185 kB]
Get:9 http://ftp.us.debian.org/debian/ wheezy/main minissdpd armhf 1.1.20120121-1 [16.2 kB]
Get:10 http://ftp.us.debian.org/debian/ sid/main transmission-cli armhf 2.82-1+b1 [306 kB]
Fetched 1240 kB in 3s (340 kB/s)
Failed to fetch http://ftp.us.debian.org/debian/pool/main/c/curl/libcurl3-gnutls_7.35.0-1_armhf.deb  404  Not Found [IP: 128.30.2.36 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
WDMyCloud:~# /etc/init.d/transmission-daemon stop
-bash: /etc/init.d/transmission-daemon: No such file or directory
Hit http://ftp.us.debian.org sid InRelease
Hit http://ftp.us.debian.org wheezy Release.gpg
Get:1 http://ftp.us.debian.org sid/main armhf Packages/DiffIndex [7876 B]
Get:2 http://ftp.us.debian.org sid/main Translation-en/DiffIndex [7876 B]
Hit http://ftp.us.debian.org wheezy/main armhf Packages
Hit http://ftp.us.debian.org wheezy/main Translation-en
Err http://ftp.us.debian.org sid/main armhf Packages
Hit http://ftp.us.debian.org sid/main armhf Packages
Fetched 15.8 kB in 5s (2994 B/s)
Suggested packages:
  libgcrypt11
Need to get 229 kB/1469 kB of archives.
Do you want to continue [Y/n]? y
Fixed it…
