Having problems reading with my Buffalo 1Tb USB 3.0, but it works fine with my Buffalo 2.0 500Gb External Harddrive. Any suggestions much appreciated. Thanks.
What issues are you encountering? I can connect my Passport 3.0 and a HP 500 GB 3.0 USB drive and both work right away.
I try to turn off media library, then same issue occur. I’m trying to play a movie from my specific movie folder and then try to pause or stop the movie. When I will play back the movie an error will pop out media is not supported. Do I need to update the firmware?I try to check my firmware version, ill add on my next post. Thanks
