hi my friends,
i have a problem with a NEW wd hdd, the model is WD2003FZEX (is a 2 TB dard disk)
i want to format is and use as an externat drive for backup but i can t format is: i tried the next methodes :
- quick format from disk management : the erros was : windows cannot complete the fromat
- normal format from disk management : the same error
- format from cmd : the erros was : the second ntfs boot sector is unwriteable
- i installed an image of windows 7, the deleted the c parition and i tried to use the hdd. i copied hundreds of gb on the hdd and after a week i couldn t acces the information
is there any method to format the hdd ?
thank for your response
