Thank you for the link on how to convert my WD HDD external drive but now I have a different problem converting. I followed those instructions and this is what I’m now getting:
C:\Windows\system32>convert F: /fs:ntfs /nosecurity
The type of the file system is FAT32.
Enter current volume label for drive F: My Book
Convert cannot run because the volume is in use by another
process. Convert may run if this volume is dismounted first.
ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID.
Would you like to force a dismount on this volume? (Y/N) y
Volume dismounted. All opened handles to this volume are now invalid.
The volume is in use by another process. Chkdsk
might report errors when no corruption is present.
Volume My Book created 2/9/2006 1:42 PM
Volume Serial Number is XXXX-XXXX
Windows is verifying files and folders…
File and folder verification is complete.
Windows has checked the file system and found no problems.
976,521,536 KB total disk space.
7,584 KB in 209 hidden files.
7,968 KB in 249 folders.
67,659,008 KB in 1,727 files.
908,846,944 KB are available.
32,768 bytes in each allocation unit.
30,516,298 total allocation units on disk.
28,401,467 allocation units available on disk.
Determining disk space required for file system conversion…
Total disk space: 976760001 KB
Free space on volume: 908846944 KB
Space required for conversion: 1283686 KB
Converting file system
Insufficient Memory
Error converting file dvd.i00.
The file may be damaged or there may be insufficient disk space.
Error converting directory NEWFOL~1.
The directory may be damaged or there may be insufficient disk space.
Error converting directory MOVIES.
Error converting directory MUSIC.
The conversion failed.
F: was not converted to NTFS
Now instead of failing the conversion because of a “dirty bit” I am now being told I have insufficient memory. I’m new at this so I’m lost at how I do not have enough memory to do the conversion. The drive I’m converting is 1TB and I’have 866GB of 931GB remaining on the drive to use still.
Someone please help me???
