Problems connecting to the live hub
Hi there,
I have just purchased a western digital HD live hub 1TB player and am having a complete nightmare. I have connect up the player itself and the wired connection. I have updated the firmware fine and have downloaded the bit off software to access the media player on the PC. I can’t get any further than that. I want to be able to copy all my movies and music on it but can’t work out how to. I am a total noob with PC’s so any advice would really be appreciated.
cheers
Graham
To access the hub from the PC you may use the WD Link software, you can download it from here:  http://support.wdc.com/product/download.asp?groupid=1010&sid=110&lang=en
To share folders from your PC, that you can then access from the hub, you can follow the steps from the link below:
http://wdc.custhelp.com/app/answers/detail/a_id/3787/session/L3RpbWUvMTMyNjY0MjUzNi9zaWQvYXU3clNjT2s%3D
