I used the WD disk to set up my drive…It erased my previous attempt at installing windows and then cloned my other drive.
My previous drive had a boot problem and had had it a long time but was slowing down so I decided to install a new one. The only issue with the old one was the NTLDR file, so I had to use the boot disk to boot up, otherwise everything worked fine.
Now, that I have cloned the drive, I am having problems opening exe files, such as Microsoft Word. And problems accessing My Computer in Windows XP.
Support said, that if I had problems with the old drive it will clone the problems over…but the problems I am having , I didn’t have before and the only problem I had, was fixed with the new drive.
It doesn’t make sense to me…Was wondering if anyone had any advice?
Thanks,
Cheryl
