Hi!!
I’m having a lot of trouble getting the remote access to my WD MyCloud to work.
I bought this a month ago, and I’m still trying to figure out what to do… I’ve read this community upside down trying to find a solution, but I’m stuck…
So here’s the story:
Every time I try to activate cloud access, update my email, get a code, whatever, I get:
Device not registered. (400143)
The device is setup with static ip, I’ve configured port forwarding on both my router and my WD MyCloud. Under Settings/General/Cloud Access the connection status is saying Ready.
Yet, that doesn’t help anything…
So, I thought my device, for some reason, were not registered in WDs systems. So I tried to register a new device. I put in all the details, but got the message: “Device already registered”.
So, then I thougt that something might have gone wrong when I registered my account. I went to wdsupport.com, and tried to register a new account, using my email. “E-mail already registered”.
Then I got back to my dashboard, and figured that if email already is registered, then I should be able to update my email in both “User” and “Cloud Access”-panels. But no; “Device not registered”.
So then I tried to go wd2go.com. Entered my email and password - nothing. Clicked “Forgot my password”, entered my email: “The email address you entered is not associated with a MyCloud.com account.”
So this is when I’m giving up… If anyone has a solution that actually works and actually will help me get cloud access to this HD, then I’d be a very happy man! I’m fed up trying to get this to work.
Please someone - what the f*** am I doing wrong here???
