renac
April 28, 2010, 8:43am
1
hi everyone! i have panasonic lcd full hd tx-l37u10e,and i bought wd tv live media player.
i ve downloaded 2 movies from the internet, 720p.blueray.x264.dts and when i play it the picture has a white dots.
when i play divx everything is ok. does anyone knows why this happends?
tv and lcd are connected with hdmi cabel.
p.s. sorry if my english is bad.
this is a picture of a movie,and you can see the problem:
It looks like macro blocks in the picture which could be a couple things. The bitrate may be too high for the player, i have streamed 40Mbit video to it without problems. The key is it must have a good connection to the data. If it is a network make sure it can get full bandwidth. If it is a hard drive over usb make sure the drive is working properly and the files are not fragmented.
Hmmm. It *does* look like a bad encode.
The WDTV won’t do this if it’s choked for bandwidth; it’ll just pause and stutter.
If you bring that file up on your PC, do you see the same thing?
renac
April 28, 2010, 3:04pm
4
the movie is on hdd (transcend),i played it on the computer and it looks ok (i"m not sure if my laptop is HD,but when i played that movie there where no white dots like on wd tv,it looked ok)
Can you post the output of MediaInfo for one of those files so we can inspect that?
renac
April 28, 2010, 4:41pm
6
General
Complete name : D:\Filmovi\Ninja assasin\Ninja assassin.mkv
Format : Matroska
File size : 8.46 GiB
Duration : 1h 38mn
Overall bit rate : 12.3 Mbps
Encoded date : UTC 2010-03-19 13:43:21
Writing application : mkvmerge v3.1.0 (‘Happy up here’) built on Jan 19 2010 12:09:24
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 38mn
Bit rate : 10.5 Mbps
Nominal bit rate : 10.8 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.280
Stream size : 7.25 GiB (86%)
Title : x264 - 2 passes @ 60% of the original bitrate
Writing library : x264 core 89 r1471kGIT 1144615
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=2 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=10774 / ratetol=1.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:0.00 / pulldown=0 / nal_hrd=none
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.04 GiB (12%)
Title : DTS - 1536 kbit/sec
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Text #2
Format : UTF-8
Language : Dutch
