Hello All,
Thanks in advance for your time and advices.
I bought 1 month ago a Wireless Pro Driver. I back up my 2 iphones without any troubles. All data inside.
I turn it on last week and the 4 top light start blinking with the wifi light. Cant access anything.
I try to access from web, cable, iphone Apps nothing worked.
I dowloaded the last firmware, format my SD card in FAT32 (how many kilobytes should i choice? 16?32? ), i tried also in ExFat.
I tried a couple a possibilities but not working
SD card was inserted unlocked. I start the Drive, but didnt want to start installing/booting with the SD Card.
I aslo tried with the push 5sec on the SD button after starting the drive
I tried also reseting by pushing the 2 buttons.
Nothing worked.
Have you experienced that kind of troubles?
How can I solve it?
Cheers,
John
