Problem with WDC WD30 EZRX-00MMMB0 and linux
hi,
I plug this drive into my laptop thru a usb sata bridge. I cannot even partition it:
Aug 26 11:13:39 host kernel: usb 2-1: new high speed USB device using
ehci_hcd and address 9
Aug 26 11:13:39 host kernel: usb 2-1: New USB device found,
idVendor=152d, idProduct=2338
Aug 26 11:13:39 host kernel: usb 2-1: New USB device strings: Mfr=1,
Product=2, SerialNumber=5
Aug 26 11:13:39 host kernel: usb 2-1: Product: USB to ATA/ATAPI bridge
Aug 26 11:13:39 host kernel: usb 2-1: Manufacturer: JMicron
Aug 26 11:13:39 host kernel: usb 2-1: SerialNumber: 000001D91CA1
Aug 26 11:13:39 host kernel: usb 2-1: configuration #1 chosen from 1 choice
Aug 26 11:13:39 host kernel: scsi12 : SCSI emulation for USB Mass
Storage devices
Aug 26 11:13:44 host kernel: scsi 12:0:0:0: Direct-Access     WDC WD30
EZRX-00MMMB0          PQ: 0 ANSI: 5
Aug 26 11:13:44 host kernel: sd 12:0:0:0: Attached scsi generic sg2 type 0
Aug 26 11:13:44 host kernel: sd 12:0:0:0: [sdb] Very big device.
Trying to use READ CAPACITY(16).
Aug 26 11:13:44 host kernel: sd 12:0:0:0: [sdb] 5860533168 512-byte
logical blocks: (3.00 TB/2.72 TiB)
Aug 26 11:13:44 host kernel: sd 12:0:0:0: [sdb] Write Protect is off
Aug 26 11:13:44 host kernel: sd 12:0:0:0: [sdb] Assuming drive cache:
write through
write through
Aug 26 11:13:44 host kernel: sdb:
Aug 26 11:13:44 host kernel: usb 2-1: reset high speed USB device
using ehci_hcd and address 9
Aug 26 11:13:45 host kernel: usb 2-1: reset high speed USB device
Aug 26 11:13:46 host kernel: usb 2-1: reset high speed USB device
Aug 26 11:13:46 host kernel: sd 12:0:0:0: [sdb] Unhandled error code
Aug 26 11:13:46 host kernel: sd 12:0:0:0: [sdb] Result:
hostbyte=DID_ERROR driverbyte=DRIVER_OK
Aug 26 11:13:46 host kernel: sd 12:0:0:0: [sdb] CDB: Read(10): 28 00
00 00 00 00 00 00 08 00
Aug 26 11:13:46 host kernel: end_request: I/O error, dev sdb, sector 0
Aug 26 11:13:46 host kernel: Buffer I/O error on device sdb, logical block
This is on a host running a rhel 6 clone, kernel is 2.6.32. The host is 64bit enabled.
Has anyone used such a drive with linux? what kernel version?
TIA
Hi there, check this post.
