My passport fell down and now when i connect it to my pc can’t reade it.Is there any way that i can retrieve my files???Please i need help because i have important files inside.Thank you !!!
http://support.wdc.com/recovery/index.asp?lang=en&selregion=americas
Try diff cables. Also check drive status under disk management if your using windows comp.
start/Rclick comp/manage/disk management/
