Hi, I have a movie with a VBR audio track . When I play the movie, after a few seconds the audio drops out. When this happens it seems to put the WDTV into a bit of a spin because after that point whatever file I choose to play I get a “this format is not supported” message. It takes a power disconnect to get things playing again.
When I attempt to play the same movie again - same result.
I do recall reading something about the WDTV having issues with VBR audio tracks. Assuming other WDTV’ers have encountered this issue, what’s the workaround?
Dave
Nah, I’ve never heard that…
After all, there’s a BUNCH of VBR in movie audio…
Please post the full TEXT output of MEDIAINFO for this file you’re having an issue with.
http://mediainfo.sourceforge.net
Here’s the Mediainfo:
Format : MPEG-4
Format_Commercial_IfAny : XDCAM EX 25
Format profile : Base Media
Codec ID : isom
File size : 1.52 GiB
Duration : 1h 26mn
Overall bit rate mode : Variable
Overall bit rate : 2 511 Kbps
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 26mn
Bit rate mode : Variable
Bit rate : 2 248 Kbps
Maximum bit rate : 25.0 Mbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.137
Stream size : 1.36 GiB (90%)
Title : movie 2007 1080p bd9 x264-bdisc
Writing library : x264 core 89 r1471M 1144615
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2248 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=vbr
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 26mn
Bit rate : 265 Kbps
Maximum bit rate : 278 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 161 MiB (10%)
Language : English
I don’t. I also have nothing but VBR tracks and all of them play back just fine.
