Hello, I have 2 wd cloud (MyCloudPR4100), with same firmware versions,
2.30.193. The first one is configured with users password acces and etc. the second one is new one. I want to upload configuration file from from already configured cloud to the second (new cloud device). When i try to import the configuration file i get error "invalid configuration settings file upload. Select correct file and try again.
Hi touchpoint,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
