Hello guy’s.
I have two WD media players, the old one , and the last one, the problem is that some files avi or mpeg are working with the old!!! WD and not with the new.
For example the file with the below characteristics:
General #0
Complete name : fantasmenos.mpg
Format : MPEG-2
Family : MPEG-2
File size : 3.18 GiB
PlayTime : 1h 33mn
Video #0
Codec : MPEG-2 Video
PlayTime : 1h 33mn
Bit rate : 9000 Kbps
Bit rate mode : CBR
Width : 720
Height : 576
Aspect ratio : 1.000
Frame rate : 25 fps
Standard : PAL
Bits/(Pixel*Frame) : 0.868
Delay : 45000
Audio #0
Codec : AC3
Bit rate : 160 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Delay : 0 / 45000
Video0 delay : -45000
ChannelPositions : L R
what is wrong??
The new Live WD media player responds with not supported file, with the old WD media player working fine.
Thank you very much,
harris
