I have used makemkv for SD files (no compression) and also HD files (compressed with Handbrake)
They load and play fine on the Hub but I can’t play an SD file and then a HD file in sucession without the box freezing. I then have to turn it off at the mains and restart it.
Has anyone else had this problem?
I have tried playing a HD first then an SD file but still get the same problem. Also, as a side note when I play an SD file the screen is green until i fast forward it and then the picture appears. Sometimes I have to fast forward it several times until it corrects itself.
All files play ok on PowerDVD and VLC.
Thanks in advance!
Michael
