Having problems playing back MPEG4 (blue ray/dvd rips) on hard drive USB connected to router. WD Live is networked via ethernet. (previously playing via XBMC/VLC)
Can see the movies, yet when try to play - looks like it plays as an audio file rather than video with audio. So soundtrack plays but no picture.
Have used mediainfo and example of movie having issue:
Bitrate of around 2000 kbps/23.9fps/1920x800
1 video stream AVC 1 audio AAC
Looking at manual seems that this should work? Is it the bitrate? Read that might be connected with how outputting sound (currently via HDMI).
Have updated to latest firmware.
Have requested WD support but grateful for any advice/help.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.44 GiB
Duration : 1h 40mn
Overall bit rate mode : Variable
Overall bit rate : 2 054 Kbps
Encoded date : UTC 2013-09-20 05:23:58
Tagged date : UTC 2013-09-20 05:23:58
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 40mn
Bit rate mode : Variable
Bit rate : 93.7 Kbps
Maximum bit rate : 103 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 67.1 MiB (5%)
Language : English
Encoded date : UTC 2013-09-20 05:24:15
Tagged date : UTC 2013-09-20 05:24:17
But even more dissapointing is the really poor (non existent) support from WD. Requested support a week ago and apart from the automatic case open email heard completely nothing! Have raised another and will wait patiently…zzzz
