Just installed a MBL under Win7 and I am having problems with passwords. As soon as I set a password on a user or on the MBL itself, the Backup and Restore tabs are greyed out in WD Smartware.
So, for the time being, I work without passwords, but this can not be forever…
If you are using the latest version of Smartware there should be an option for choosing which Share you backup to.
Try selecting the Smartware share, then the Backup / Restore tabs should be available again. You could also select a Private share you have created, then click on the MBL’s icon in Smartware. It will then prompt you for the user/pass to access the drive.
I am using the latest version of WD Smartware (1.6.4).
I seem to have no problem when putting a password on My Book Live (admin) itself. But as soon as I put a password on the user (public, no private share), the tabs backup and Retrieve are greyed out and WD Smartware seems unable to connect to the external drive:
