I recently bought a tv live hub. After uploading my photos, I noticed a problem with the way they are displayed. The photos on my USB hard drive which are best viewed vertically, are showing as horizontal on the hub. The normal horizontal photos are fine, its just the vertical ones which are displayed sideways. Aside from individually rotating the photos on the hub, is there a quicker way to fix the hundreds of photos? Thanks for any suggestions!
You could select all the photos and rotate them in Xnview (free program). Make sure you select all the photos you want to turn and then press the lossless rotate button at the top. After you have down this the WDTV will show them correctly.
But they are already rotated on the pc? Does anyone else have this problem? I imagine it would be quite common. Thanks for any suggestions
My guess is what’s happening is that the application you’re using on your PC to view photos is reading the EXIF data.
EXIF data has an ORIENTATION tag that indicates the orientation in which the photo should be displayed.
It looks something like this:
EXIF tags in 'DSC_5762.JPG' ('Motorola' byte order):
Tag |Value
Manufacturer |NIKON CORPORATION
Model |NIKON D60
Orientation |left - bottom
[snip]
FNumber |f/5.3
Exposure Program |Not defined
ISO Speed Ratings |200
Exif Version |Exif Version 2.21
Date and Time (origi|2011:01:08 17:11:20
Date and Time (digit|2011:01:08 17:11:20
Components Configura|Y Cb Cr -
Compressed Bits per |4.00
Exposure Bias |0.00 EV
MaxApertureValue |4.80 EV (f/5.3)
Metering Mode |Pattern
Light Source |0
Flash |Flash fired, auto mode, return light detected.
Focal Length |40.0 mm
Maker Note |28622 bytes undefined data
User Comment |
SubsecTime |80
SubSecTimeOriginal |80
SubSecTimeDigitized |80
FlashPixVersion |FlashPix Version 1.0
Color Space |sRGB
PixelXDimension |3872
PixelYDimension |2592
Sensing Method |One-chip color area sensor
File Source |DSC
Scene Type |1
CFA Pattern |8 bytes undefined data
Custom Rendered |Normal process
Exposure Mode |Auto exposure
White Balance |Auto white balance
Digital Zoom Ratio |1.00
Focal Length In 35mm|60
Scene Capture Type |Standard
Gain Control |Normal
Contrast |Normal
Saturation |Normal
Sharpness |Normal
Subject Distance Ran|Unknown
InteroperabilityInde|R98
InteroperabilityVers|0100
 Note the orientation says “LEFT-BOTTOM”
That flag indicates that, to display in the “Correct” orientation, the TOP LEFT of the photo, as it exists in the file, should be rotated to the LEFT-BOTTOM.  In other words, Counter-clockwise 90 degrees, to display in the same orientation the CAMERA was held.
The Hub is most likely ignoring the tag, OR the tag is incorrect to begin with.
Programs like GIMP will tell you what the orientation SHOULD be, but it will open the file AS-IS.
If you want to bulk-rotate your files so that they work correctly with the hub (and also won’t screw up the EXIF tag)
you can use the freeware program MOGRIFY to do it en masse:
You may have rotated them on the PC but it may not be saving that info to the photo. The hub needs to know the orientation so that it can display it correctly. I suggested a way out of your problem. It should not take too long to install the program and try it out.
The problem is quite common and I use this program to correct the exif info attached to the photo. If you think about it most cameras have no idea of the camera orientation so they write a default of landscape mode to the exif info. You have to change that so that the hub knows how to display it.
