Problem with my Passport USB 3.0
#1
I have install my Passport during Windows 7 , and that work FINE…
But when I try to use it , on my another PC( during XP), i got : Error…
MY Q = Can’t I USED ON BOOTH - XP AND WINDOWS ( SWITCH WITH NEED)…???
bEST REGARDS- Bg1bpe - from Swe
#2
Hi dude!!
What specific error is the one you get? It can be extremely helpful since there are tons of possibilities in here!
You should be able to use that drive on the 2 OSs, but a lot of things come into play like stability, the age of the computer, updates, drivers, optimization and overall configuration just to mention some!
Hope it helps!
#3
most likly you are useing the 3.0 cable try using the micro 2.0 cable for xp.
