I used the “Reset to factory default” feature from the unit software…and it didn’t help much.
Then I dig a bit on the forums and I found a lot of complains regarding 1.04.10_V new release and I followed instructions to downgrade my firmware to 1.03.49_V. After downgrading finished, the video stream problem on .VOB files was gone, but still cannot play mp3’s and any other .avi file format.
I wonder if my unit was damaged by 1.04.10_V update release.
The unit cannot be “damaged” in the manner you describe by a firmware update / downgrade (i.e. some features stop working but otherwise unit is functional).
Can you provide more info about your network setup and how you stream your media?
Network shares or media server?
If media server, what media server do you use?
If network shares, what is the network share device (Win PC or NAS?)…?
Have you tried power cycling the unit? In other words, pull out the power for a few minutes. If you have played a badly encoded file, sometimes that can confuse the unit until it is fully powered off and then restarted.
Thank you for your comments PixelPower…at least now I know that the unit is physically OK.
The unit is used on wireless network with Win XP Pro network shares.
The unit has been hardbooted many times, without much success.
What I found weird is that the unit worked fine and played all my .avi’s and .mp3’s and other files until it update to 1.04.10_V. All my issues started with that update…
…right now I don’t know what can I do more from here.
My since 1.02.21, still does not detect an HDD WD Caviar Green 1TB WD10EACS, other brands I have no problem, I have to change to the firmware 1.01.24 every time I see something of that record and return to the last to hold the Internet Options.
WD lords, should I go on much longer?
How is it that an album of his own brand does not work, you do not understand and I am not alone, I read the odd comment about it but WD does nothing.
