My WD TV LIVE HUB is connected to the internet via an Apple Express. For several firmwares, when I plug the Ethernet cable to the WD TV LIVE HUB, the picture freezes after a few seconds and I have to unplug the Ethernet cable and the power cable and then reconnect.
You really should post this problem in the main forum. This board only really reports issues to WD and is not a discussion board where you can get support from other users.
Please edit your post to add the missing information while adhering to the specified guidelines on the right panel in order for this issue to proceed from “More Info Needed” to “In Review”. This Issue shall remain frozen until this has been done. Regards, Robothief.
