Yes, I know, there are some other threads relative to similar problems but I think not for WD Live HUB
I need to connect the WD Live HUB to a Sony CRT TV with only has 3 SCARTs and 1 Composite inputs
I though I could buy a omponent to SCART cable or a SCART/Component adapter to plug to my TV but simply does not work. The image remains black when I switch to that input.
TV manual says the 3 SCARTS support S-Video (2 of them) and RGB
It doesn’t say specifically the SCART on TV supports Component.
Can this be the problem? or the SCART which supports RGB should also support Component?
Am I doing something wrong or there is no way to connect via component the WD Live HUB with my Sony Wega CRT?
Composite works fine! But I think everything is a bit too dark so I wanted to switch to Component if possible. Anyone also has the problem that colors via composite are too dark?
Please help!!
