When I play this AVI file on my WD TV Live with the latest firmware, the sound is out of sync and also the picture stutters every few seconds. When I play it on my pc, there are no problems. I used Handbrake to make an MKV file of it, and the mkv file works with no problem on my WD TV.
Somebody who knows what the problem is with this avi file?
General
Complete name : C:\Users\Downloads\ZS.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 557 MiB
Duration : 55mn 40s
Overall bit rate : 1 399 Kbps
Writing library : TMPGEnc 4.0 XPress Version. 4.7.6.304
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : 3 warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 55mn 40s
Bit rate : 1 199 Kbps
Width : 656 pixels
Height : 368 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.199
Stream size : 478 MiB (86%)
Writing library : XviD 58
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 2000
Duration : 55mn 40s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 76.5 MiB (14%)
Alignment : Aligned on interleaves
Interleave, duration : 240 ms (6.00 video frames)
Interleave, preload duration : 224 ms
