Hello. I have a DVD-9 wich uses AVCHD, it can be played (with no problem) in a bluray player. I took that DVD and then converted it into a ISO file (with UltraISO) for the WD TV Live to play it. The reproduction starts fine, everything is fine but after a few seconds out of the blue the video starts to play very fast like when you are pressing the foward button. To stop this I have to rewind then press the play button and the playback is back to normal.
So maybe as you guys said the WD TV Live Plus doesn’t support reading AVCHD from an ISO -bluray players read a file called index.bdmv and then play invidivual AVCHD files-
Anyway I solved this by converthing the files into avi (XviD HD 720p) and it’s working like a charm :D.
