Hello i’m here because i’m in front of a problem with my mac and my EX4.
I have 2 WD RED 3To in Jbod format and I would like to transfer files and folders from one who is connected by USB to the other who is connected by ethernet.
the problem is that i can’t transfer files with their respective folders, i can read that the problem comes from the .wdmc ???
Your Mac OS computer may not read your WD Red hard drive using the EXT4 file system. You need a Linux-based system, or an application able to read EXT4 volumes. If the volume itself is healthy you should be able to access your content.
I already used the application Paragon ExtFS for Mac OSX and I it works perfectly, I can access to all my content, that’s not the problem.
My problem is that I can’t past a folder from my hard drive EXT4 format to my other hard drive Jbod format in my NAS, I have this message: Unable to copy the “.wmdc” element because its name is too long or contains characters that are invalid on the destination volume.
I did it, I think the problem comes from the hide folders .wmdc that we can find in all folders for example
If I have a music folder, you will have the .wmdc in it and in all albums too, so when I try to copy the music folder, it doesn’t work, but if i created directly folders in my hard drive, copy and past only the files from each folders, all works fine.
With carbon copy I can see and unchecked these hide .wmdc folders, so all works
I think I need to delete .wmdc from my wdmycloud dashbord ?!?
