I have a problem playing the files from Panasonic DMC-TZ7 which produces AVCHD files. I rename the MTS extension to something else and files get recognized but they seem to be played with a half framerate.
Sound is ok but the video is jerky and like slow motion. It’s always like that regardless of a video output setting of WDEP.
Below is a video stream info, is it because of high bitrate or something else, anyone has an idea ?
Format : BDAV
Format/Info : Blu-ray Video
File size : 40.5 MiB
Duration : 22s 336ms
Overall bit rate : 15.2 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Duration : 22s 320ms
Bit rate : 14.4 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Standard : NTSC
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.313
Stream size : 38.3 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 524 KiB (1%)
Format : BDAV
