Problem in WD5000AADS Caviar Green
Caviar Green WD7500AADS fails the Western Digital Data LifeGuard Diagnostics Quick test with following error message:
06-Quick Test on drive 1 did not complete! Status code = 07 (Failed read test
element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not
complete on drive 1!
and also Extended test
08-Error was detected while repairing bad sectors.
also computer freezes very often and displaying Data error (cyclic redundancy check) while copying. what should i do?
would appreciate any help.
p.s. OS: Windows 7
Intel P4  3.06 GHz
Intel Desktop Board 945GCL
and also tried Windows Checkdisk utility.
i’ve just had my drive do this and am now rma back to wd as only 6 months old
if yours is in warranty i suggest you do the same after getting what data you can off the drive
and now here i am again, new rma drive has just got the same problem
do these green drives have a manufacturing problem?
how do i get my money back as i dont want the 3 week wait i had last time to get a new drve that then fails again
DLGDIAG for Windows
Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test)
SMART self-test did not complete on drive 1!
OK
in last two month, i replaced my drive two times because bad sectors problems. again i’m experiencing the same problem with the third one.
Is there some manufacturing problem with WD Caviar Green …
i don’t want to replace a drive/month. someone plz help
WD6400AADS-00M2B0
Windows XP SP2
Intel P4  3.06 GHz
Gigabyte G41M-ES2L
im sorry mate but im thinking that is some problem with the power supply or motherboard…
try changing the power supply first :slight_smile:
Hi David,
    i already checked power supply and changed my motherboard three weeks before. i also have a second HD, which i use during the replacement time but there is no problem with that drive.
  i bought the drive in feb. after 40-45 days it developed the bad sector. the drive i got in replacement didn’t pass the DLGDIAG test and now this is the third disk having the same problem. :cry:
**bleep*** so much bad luck…
HEEELLLPP!
Yea ordered the 500 green off Newegg and I dont think the driver cd came with it. Can someone help and point me in the right direction as to where I can download the driver for windows 7? Guess Win dosnt come with basic drivers anymore huh?
If someones got an answer for me, can you please email it to me at antillas606@hotmail.com? Thanx
