Glad I could help!!!
You are very welcome!! Happy to help out!!..
Hi Estemarez, this doesn’t work for me. I installed Wd Security, WD Drive Utilties, but cannot mount it on Mac Big Sur 11.1. It worked with prior versions of Mac software. I opened Wd Security and tried setting/unsetting a password, and then trying to mount on Mac Disk Utility, but I always get the same error. Could you elaborate on your steps?
?worked very well for me! Thank you, you’re great!
You’re a lifesaver, sir! I was so frustrated, and now it works perfectly!
WD NEEDS to fix this crappy software that’s causing so many issues for people!
