I bought a recent Sony SVF series laptop with Windows 8 64bits and a 500GB Hitachi disk containing several partitions (see below MSINFO32 infos).
Once laptop runnning and settings ok, I wanted to have a backup copy, meaning a clone of the disk and I bought for that a Western Digital Scorpio Black WD5000BPKT disk.
I tried to do the clone operation with Acronis 2013, with EASUS 6.0, and with Disk Image XML, without success.
After some searches, it appear that the source disk has a 512 bytes sector size, and the WD destination disk a 4Kbytes sector size.
I put the WD disk on a Windows 7 machine and tried to format it as FAT Extended (512bytes) format. The operation seems succefull but once connected to the Windows 8 laptop, the clone operation once again failed with the same error (and MSINFO32 still indicate that the WD disk has a 4Kbytes sector size).
So, now what can I do ? How can I change, if this is possible, the destination disk sector size ?
Thanks by advance for any help.
Edwige
Here are MSINFO32 storage infos:
(this is the source disk)
Description Lecteur de disque
Fabricant (Lecteurs de disque standard)
Modèle HGST HTS545050A7E380
Octets/secteur 512
Média chargé Oui
Type de média Disque dur fixe
Partitions 8
Bus SCSI 0
Unité logique SCSI 0
Port SCSI 0
ID cible SCSI 0
Secteurs/piste 63
Capacité 465,76 Go (500 105 249 280 octets)
Nombre de cylindres 60 801
Nombre de secteurs 976 768 065
Nombre de pistes 15 504 255
Pistes/cylindre 255
Partition Disque n° 0, partition n° 0
Taille de partition 260,00 Mo (272 629 760 octets)
Offset de démarrage de la partition 1 048 576 octets
Partition Disque n° 0, partition n° 1
Taille de partition 1,44 Go (1 545 601 024 octets)
Offset de démarrage de la partition 273 678 336 octets
Partition Disque n° 0, partition n° 2
Offset de démarrage de la partition 1 819 279 360 octets
Partition Disque n° 0, partition n° 3
Taille de partition 68,36 Go (73 400 320 000 octets)
Offset de démarrage de la partition 2 226 126 848 octets
Partition Disque n° 0, partition n° 4
Offset de démarrage de la partition 75 626 446 848 octets
Partition Disque n° 0, partition n° 5
Taille de partition 226,07 Go (242 735 906 816 octets)
Offset de démarrage de la partition 149 026 766 848 octets
Partition Disque n° 0, partition n° 6
Taille de partition 68,36 Go (73 399 271 424 octets)
Offset de démarrage de la partition 391 763 722 240 octets
Partition Disque n° 0, partition n° 7
Taille de partition 25,31 Go (27 179 089 920 octets)
Offset de démarrage de la partition 472 928 747 520 octets
(this is the destination disk)
Modèle WDC WD50 00BPKT-00PK4T0 USB Device
Octets/secteur 4096
Média chargé Oui
Type de média Média amovible
Partitions 1
Bus SCSI 0
Port SCSI 0
ID cible SCSI 0
Secteurs/piste 63
Capacité 465,75 Go (500 097 024 000 octets)
Nombre de cylindres 7 600
Nombre de secteurs 122 094 000
Nombre de pistes 1 938 000
Pistes/cylindre 255
Partition Disque n° 1, partition n° 0
Taille de partition 465,63 Go (499 971 522 560 octets)
Offset de démarrage de la partition 135 266 304 octets
