Problem downloading torrent
Every time I try to download a torrent directly to th WD my home i’ll get a message in Utorrent as shown below.
Even after the torrent is completed I recieve this message from time to time from all the torrents that has data on the WD my home. Does anybody now why?
All connections is through a gigabit router and switch and can’t se that the wd my home disconnects anywere.
Hi PatrikO,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
Create a Support Case
Create a support case with our world-class service and support team.
i had this problem , and i solved it by uninstalling WD discovery and reinstall the latest version , then restart the computer and i never had this issue again
i hope this works for you
