I have a working Windows 10 installation on an Edge 500GB Sata SSD, and I’m having difficulty cloning it to a SN750 1TB NVMe drive.
I have a ASUS ROG Maximus VII Gene motherboard, and if I remove the Edge SSD, I’m able to install a fresh install of Windows onto the SN750 just fine. If I just plug the SN750, and boot into windows (off the Edge), I can see and format the SN750 just fine.
I’ve tried to clone it using both Clonezilla (latest) and Arconis True Image. When using Clonezilla, the resulting clone just hangs at boot. With Arconis, the clone blue screens with “boot device inaccessible”. In both situations, the clone was performed with both drives hooked up to the motherboard (no USB), and then the Edge was removed after the clone, and the attempt to boot was made with the SN750 the only drive.
I’m okay with re-installing windows, kinda…but I’d really like to migrate the existing install to the SN750.
Anybody have any suggestions?
