Hello
I have a router running OpenWrt as a NAS. The Wd Tv Live cannot access the NAS neither trough samba or nfs. It can access only Windows share.
It is not a firewall related problem, the firewall is down.
Thank you
Hello
Thank you
Your post makes no sense.
For one thing, the WDTV Live does not support NFS, so that’s no surprise.
But this:
Cannot access the NAS neither trough samba …It can access only Windows share.
Windows Sharing *IS* samba.
I have a similar problem, with my TV Live Hub.
On the network I have a NAS disk, a Conceptronic CHD3NET, with a 500Gb disk. Buy windows I can access the several folder on this disk, I can copy, delete, change… ect.
However the Tv Live Hub, can’t detect the disk on the network…
Another information, I can access the internet services…
Thanks for all the Help!
Best regards,
Carlos Loureiro
Hello Again,
I have solved my problem… The Wd Tv Live Hub, was on a different workgroup…
I have changed on the WD Tv Live Hub under “SETUP / NETWORK SETTINGS / WORKGROUP”, after change the WD Live TV Hub automatic reboot…
I tried to look the NAS disk and… there is was… :smileyvery-happy:
Thanks Any way!
Carlos Loureiro
