My 3TB External Western Digital hard disk is not detected from my last firmware update…
some else having problems?¿
MAGICIAN
MAGICIAN
hi there
it should have been,it should take some more time but would finally mount .
pls check :
* latest updates for your 3tb book ? Plug in your 3tb via usb to your laptom/pc which has net connection and check updates
* library is set off or on ? [within you wd media player]
* are you sure it worked perfectly with the latest fw - say a day ago ?
regards
pawson
Definetively my WD Live doesn’t see my 3TB Book…
The last 1.06.15_V firmware fu… this capability
