PRO Series PR 4100 - FAN SPEED CRITICAL Notification
I cant barely connect to my PR4100 settings and when it happens on the diagnostic shows a FAN SPEED CRITICAL SIGN. The LAN connection is intermittent and unable to establish a stable communication causing the saving and working almost impossible. Is very URGENT (today) to get access to some files. Planning to on buying a temporary bay to get thru the day.
Is the FAN SPEED notice causing this unstable communication? Advise on what drive bay should I get.
Seems like your system maybe getting too hot. Not sure what you mean by drive bay. Pls contact the WD Support directly.
https://support-en.wd.com/app/Contact_Us
I mean hard drive dock to remove the drive from the PR4100 and use it as external hard drive. Of the 4 drives which get to stores the information first?
