Hi, My PRB card is gone (2060-701266-001 REV A) out of my WD2000BB. I would like to know if I can replace it with a PRB (2060-001292-000 REV A) if I change the BIOS chip? Physically, they both have the same physical pattern.
Tks
Tks
Hi there,
I have not tried this, lets see if another user can share some tips or information on this matter.
I installe di tlast night and the HD was doing a clicking noise. If nobody respond, I will try to swap the BIOS chip
Tks
I ordered a PCB replacement from PCB Solution and they are simply the best!!!
