Are there any recommended uninterrupted power supplies for use with the PR4100? Does the PR4100 have a power supply that requires an uninterrupted power supply with pure sine waves?
Take a look at this link. Hope it helps.
http://support.wdc.com/knowledgebase/answer.aspx?ID=11852&lang=en
My Eaton 3S 700 seems to be accepted as well. At least when connected via USB, the USB port indicator shows “EATON Battery Charge: 100%”
My CyberPower CP1350AVRLCD is supported. It shows on the USB port. Wish there was a way to configure the alerts based on battery level.
