I want to configure my PR2100 to use iSCSI with redundancy. I have configured link aggregation on the NICs to none, gave each NIC a different IP address (on different subnets) and connected each NIC to a different switch. Now I have a windows machine connected to both switches. When I create an iscsi target on the PR2100 I get only one discovery portal and only one target name for the target and when I try to connect from windows using iscsi I only see one target.
How can I make an iscsi connection from the windows machine use both NICs for maximal throughput? preferably using the 2 switchs and if not possible using only 1 switch
