Hi
I am having a problem trying to create a PPPOE Connection from my notebook using using the Windows WAN Mini Port network connection option.
I have a WD My Net N900 router. with Firmware Version 1.07.16
(The router is connected to the DSL modem, which is using a different ISP, and is working fine)
If I bypass the router and connect the notebook directly to the DSL Modem I am able to connect, so I assume the connection is getting blocked by the router somehow (error 651).
Any suggestions on how to get this to work?
