I have the 1TB white light model setup on my home network. I use it for itunes and system backup of my Macbook running Snow Leopard.
I recent had to use the reset button on the back of the hard drive (I forgot my password for the web interface). NOw ever since I did that, the drive will not powerup correctly.
When I plug in the powercord, the front light turns on, I can here it spinning up, but after 25-30 seconds, it turns back off. I have done the obvious things of double checking power cables, and plugged it in directly to a wall instead of a UPS.
Any ideas would be a great help.
