Power Surge On Hub Port issue
Hi, I have 2 WD Element 1TB and brought a WD My Passport 4TB for a while.
Normally I use my Element USB3.0 cable with all my 3 drives and they work fine.
But, recently I grabbed My Passport USB3.0 cable from the box and use it for the 1st time and then my PC showed “Power Surge On Hub Port” alert. I tried this cable with all my drives, none of them work.
Is my cable broken? or
My Passport USB3.0 cable draw power more than Element USB3.0 cable? I search the internet and found that My Passport consumes more power. Isn’t that the drive, not the cable?
Thanks in advance
Hi souleater,
You can refer the link given below and follow the instructions to resolve such issue.
https://support-en.wd.com/app/answers/detail/a_id/16704
