Hi. Need to extend my power supply cord. Can you tell me what the dimensions are of the plug that goes into the back of the unit? I think it’s probably something like 5.5mm x 2.5 or 2.1mm, but need confirmation before ordering. Thanks
Hi surfmonkey,
You can refer the link mentioned below to get the information about the Power Adapter for your My Cloud Home device.
Hi Brandon
One of your colleagues answered this query on the 17th.
Kind regards
